Gaskets & Seals for S16 head
I need help sourcing the following
Joint closing plate cam, this goes on the gearbox end of the exhaust cam - OEM Part No: 023645
[attachment=22597]
Rocker cover seal for the spark plug tube - OEM Part No: 021306
[attachment=22596]
I had a conversation with a very useful Peugeot parts man but unfortunately these parts have been discontinued by Peugeot.
Can anybody point me in the correct direction? I do not like using liquid gasket, it is horrible stuff  Nospeak
If anybody is interested I found the spark plug hole seal
http://www.ebay.co.uk/itm/Peugeot-405-2-...1104179206
Could be useful to somebody.
I usually find taking the peugeot part number into eBay on its own brings up things you would never find by searching for its name! Give it a go Wink
Thanks given by: lpr1981
If you stick a oil seal on that cam you won't need a seal
(10-04-2015, 07:16 PM)miles Wrote: If you stick a oil seal on that cam you won't need a seal
I will have a measure up and see what is about, if not I will make the gasket as it seems to be non existent.
