Rallye Fan/Loom Connector
After taking the fan connection off the loom I found an issue. One of the spades was badly corroded.
I scraped out a lot of the corrosion but it's still pretty bad and now I'm missing one spade.
Can these come apart?
[Image: 2015%2B-%2B2]
Left connector: fan
Right connector: loom
The blue mess is where I think the spade should be in the fan side. I've attacked it to get in but with no luck.
Would the easiest option be a new fan loom? (anyone got such a thing?) or find one, cut it up and re-seal it myself? Not ideal.
On the right the larger single spade is very loose in its holder.
How do get in to fix these? I hate car electrics.
I sees you post here too. I stand by my gti6 forum answer. Tongue
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Ah same picture, different alias!
  ph1 and ph2 engine loom connector differences jirupa 23 23,073 08-02-2021, 12:40 PM
Last Post: Mighty306
  Seatbelt tensioner connector tigerstyle 2 3,024 17-03-2017, 12:07 PM
Last Post: Mattcheese31
  Phantom Connector Eddleston 3 3,021 21-12-2014, 06:16 AM
Last Post: j-n-88
