Transmission problem
hey i have my 2001 306 1.6L automatic transmission problem.. the car will jolt and then on the dash board the Sport and Ice lights will flash.. To correct the problem I have to turn off the car and restart it please help
by the way i have added one liter of synthetic fluid
Did you just add the fluid or did you drain the old stuff first?
Unfortunately if an oil change doesn't help, you really need the transmission ECU read for fault codes.
i didnt drain any becuase i dont know how lol
Ok well I'd suggest a fluid change rather than just chucking more in lol.
I've never owned an auto 306 so I'm not sure how to drain them either though, sure someone more knowledgeable will be along soon.
Don't mean to be harsh, but if you don't know what you're doing you're best off leaving it well alone, or at the very least having a read around about what the problem might be before just doing what seems like a good idea. Had a corsa in a while back whose owner had taken the same approach as you to the engine oil, needless to say it was ruined and cost him about £600 to fix.
(24-03-2015, 11:55 AM)sm0ke Wrote: hey i have my 2001 306 1.6L automatic transmission problem.. the car will jolt and then on the dash board the Sport and Ice lights will flash.. To correct the problem I have to turn off the car and restart it please help
Hello mate I'm having same problems with my pug automatic gear box ive had it checked by a gearbox specialist and it's down to a high presure solenoid usual happens as it goes into 3rd gear I got a quote for £400 but they said it might not cure it for ever tho and main dealers said £65 eatch solenoid
  Original Transmission Fluid Distorted Vision 8 6,114 28-04-2015, 05:15 PM
Last Post: Pgtips
