Noticed a few things,
Right, after driving my car for a few weeks I've noticed a few things!
All faults are intermittent, and seem to go back to normal!
1: The boot won't open on occasion, but after a few tries it does.
2: When indicating right, the indicator flashes fast, as if a bulbs faulty, but is now working fine.
3: The car won't lock properly using the passenger door. And to lock the car I have to turn the key to the left and hold it for it to lock, if I just turn the key and back again it locks and pops back open again.
4: The rear window wiper (on occasion) won't work unless I turn the indicator right round to start the washer, then it will start moving and clear the back window.
All comments welcome as always! Smile
Looms between boot and car. Between doors and chassis.
Then stalks.
So does that mean they all need replacing? Are the faults due to water ingress or just general wear and tear?
Inspect and repair the looms
Indicator stalk likely need replacement
I would never know how to do that! I'm not mechanically minded at all, although I would like to learn.
Would it be a job for an auto electrician? And would it be expensive?
No and no ThumbsUp
So how could I go about getting it fixed?
