Threads: 8
Car Model/Spec: 309 2.0 HDi
Country:
Just had something weird happen. Driving at a steady 40 and there felt like there was a very slight loss of power, I glanced down and just caught the speedo needle dipping to zero and back again.
Looming crank sensor issue? I have no manual to see where the speedo gets it's signal from.
Threads: 91
83
Earth connections to chassis from the engine at a guess, that's a classic for making the speedo go funny - the speedo is driven off the diff, rather than anything to do with the crank sensor.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 21
3
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
Its your speedo sensor on the gearbox failing.
Threads: 77
1
Given 1 thank(s) in 1 post(s)
As above speedo sensor, mine used to do the same.
Threads: 581
195
Given 81 thank(s) in 77 post(s)
Just to echo the above, its your VSS. Quite a common fault and not that expensive to sort
