Threads: 47
0
Car Model/Spec: 2001 lx hdi estate
Given 0 thank(s) in 0 post(s)
Hi all.
Hope I am posting in the correct section. How many miles will I get from my original clutch? at present it`s 169000 and pulling strong. I am running down to Newquay in july and don't want it to fail on me then. Being an old driver (63) and enjoying it. Plenty of enthusiasm for 306.
Cheers.
Threads: 591
54
Anything from 100miles to 100k miles.
Not really an answerable question I'm afraid
Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
They don't have a specified mileage as all drivers are different. It will go when it wears completely. Sorry I cant be more precise for you.
Threads: 85
8
Car Model/Spec: E90 330i
Given 15 thank(s) in 15 post(s)
It will start slightly slipping when it's on it's way out. I drove mine on motorways for a few months with a slipping clutch and it's fine as long as you drive sensibly and don't smash the accelerator into the floor
Threads: 117
119
If you've persuaded the original to last this far you should be fine, what's 300 miles to 169,000!
Are there any signs of imminent failure; ie clutch pedal stiff or not returning fully, release bearing noisy, slipping under heavy acceleration, etc?
Threads: 386
87
Are you sure its original? I haven't seen a release bearing last that long even if the clutch plate does!
As others have said though, you can't put a distance on a clutch, but it shouldn't fail without prior warning anyway, so you'd have to be unlucky for it to completely fail on the one week you're away!
