Breaking Cammed Bianca High Spec 6! PIC HEAVY
owned this car for 2 year's now and some of you may have seen it at FCS or Pugfest, Decided to break it rather then loose a fortune in money payed for parts.
Alot of parts are still shiney new, Car has seen hardly any use in the past 6 months
All parts are available, Evan the bare shell to anyone intrested, just needs some attention so front jack points
Shell has 154k, Engine has 103k, Fitted after hydrolocking the last one during last years floods.
Evreything can be posted, Obviously engine will be palleted and axle with heavy courior etc, Ive included delivered prices with some but most of them better of pm'ing me as prices varie on locations!
The specs and usuals are as follows..
Engine (103k, Cambelt & waterpump fitted 99k) Will be top & bottum end only with standard cams £300 - SOLD
Piper 270 Fast roads Done 4000 miles ( Currently fitted to engine at 99k) £200 - AVAILABLE AGAIN
Maniflow 4 2 1 MILD manifold (This is the offroad use one, Bigger better & Noisier) BRAND NEW -  £400 - SOLD
Gearbox 103k - £80
3.5 Bar genuine FPR - £30
Rallye AUX set up (Brand new, done 100 miles) - £70 - SOLD
BMC Carbon enclosed CDA Airfilter - SOLD
Inlet Manifold with injectors & Throttle body - £80
Baker BM Engine Mounts & Lower fork bush New, Not evan seen 200 miles - £100
Baker BM Brand new never used Gearbox mount - £30
Magnex 3" 2.5 S/S Exhaust Catback System, Has had the welding done so all good £120 - SOLD
B&M Short Shift (Sllide over gearshaft shaft type) £20 Delivered - SOLD
Nissens Rad VGC - £50
Rose Jointed Gear Linkages near new £25 delivered to Uk main - PROV SOLD
Unlocked ph2 gti 6 Ecu - £60
Engine loom - 30
TA Technix Coilovers, These are my 2nd set always run at 40mm so not bad - SOLD
21mm Torsion Bars, One end bolt needs attention - £80
Recently rebuilt rear axle using BRAND NEW Genuine Pug rebuild kits (Expensive) Standard 20mm bar - £300 SOLD
Baker BM Solid Rear Mounts - £100 - SOLD
Bilstein B6/b8 Rear Dampers - £70
Near New Aftermarket Wishbones - £40
Team Dynamic Pro 1.2's 16x7 Black Alloys in Reasonable
Condition,Tyres are budget, Fronts 3mm rear 5mm £250 - PROV SOLD
Near new pair of 12mm billet steel hubcentric spacers - £30
Near new pair of 10mm billet steel hubcentric spacers - £25
Gti 6 Calipers with Green stuff front pads, Pads have alot of life but discs worn out - £50
18mm Hubs, Not long fitted these - £40 pair, 20 per side
23mm Master Cylinder - £25 Delivered
Drive Shafts - £35 pair or £20 long, £15 short
PH1 GTI 6 Alacantra Seats, Bolsters are fine no rips, One small burn in center of drivers seat, P/s has small tear front underneath - £120
Rallye Door cards in VGC - £50 PROV SOLD
JVC Stereo In full working order - £40
Rallye Manual Windows - £30 per side (P/s missing handle) -SOLD
Team Heko Tinted Wind Deflectors in VGC - £25
Rallye Blanks in VGC - £15
Ph3 Front Splitter - £25
Ph3 Spoiler - £20
Luke Yellow Tow Strap (Still in wrapper unfitted)  £10
Bianca Bonnet, No dents but some stone chips - £40
Bianca Rear Bumper, Odd mark here n there but otherwise good - £30
Bianca PH2 Skirts, No cracks but maybe the odd mark - £30
Bianca Ph3 Rubstrips, Some peel and marks - £30 - SOLD
Bianca Bootlid PH3 - Needs a buff, Good condition though - £30 -SOLD
Bianca Door Shells £30 each, P/s In good condition but drivers side has peel and minor dimples - P/S SOLD
Black Mask Headlights, DIY done long time ago to a decent standard. Dont fog up etc - £45 - SOLD
2x Bianca Grills 1 some chips £10, Other in good condition £15
Bianca Wings, £40 pair or £20 each. Maybe minor marks but otherwise good - P/S SOLD
Bear with me on the photos, Its 9 o clock at night lol. I will add some of the car itself though. Please bear in mind the photos of it on nimrods are old, Its been sat at 40mm on black TD's for some time now. Car is currently together still, Will be split up within the next 10 days hopefully most sells by then so im not getting greif from the wife for using the living room as storage.
Thanks
[Image: 20141109_115156_zps6xve0hto.jpg]
[Image: 20140404_144725_zpsnxtunja1.jpg]
[Image: 20140520_153907_zpsoldxnqmx.jpg]
[Image: 20140911_135138_zpswfu2x9i9.jpg]
[Image: 20140911_183034_zpscyhlunua.jpg]
[Image: 20141109_115205_zpsoxkmen44.jpg]
[Image: 20150311_123313_zpshenzirhr.jpg]
[Image: 20150311_123317_zpso1167fdz.jpg]
[Image: 20150311_085513_zpsxblagqxg.jpg]
[Image: 20150311_085522_zpsd9nz23fk.jpg]
[Image: 20150311_085533_zpseppnqqzy.jpg]
[Image: 20150311_085538_zpshl8svb9v.jpg]
[Image: 20150311_085553_zpsbte0nsaz.jpg]
[Image: 20150311_085915_zpskv5tns53.jpg]
[Image: 20150311_085937_zpsyctjvsca.jpg]
[Image: 20150311_085857_zpsevq6ipwu.jpg]
[Image: 20150311_085910_zps4abo50ll.jpg]
Possibly interested in bonnet mate, pending pics.
Ill message u on fb too
[Image: av5ym8.jpg]
Yeah no probs bud
[Image: 20150311_085841_zpsvf6po07e.jpg]
[Image: 20150311_085834_zpsatep8o6t.jpg]
[Image: 20150311_085828_zpskhqjxz35.jpg]
[Image: 20150311_085823_zpsj1nadmj5.jpg]
[Image: 20150311_085809_zpsvfvleifl.jpg]
[Image: 20150311_085746_zpsxf4by9zu.jpg]
[Image: 20150311_085723_zpsgsulwfem.jpg]
[Image: 20150311_085752_zpswjnrk9o6.jpg]
condition of the calipers?? Smile
Good condition chap, painted yellow. Nipples free and dont bind at all
What welding has been done on the exhaust? Any pics?
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Ill grab ya some photos tomorrow chap, its been welded where they fracture around the joint to mid box
Pics of calipers too??
What about front bumper james?
Rowell should be all over this shell!
Front bumper needs paint chap, isnt cracked anywhere though
Ok look forward to pics of the exhaust. Smile
Got a couple earlier, best i could do with the car on its wheels
Will it still pass a db test for track with that manifold??
Why is it classed as off road?
Cheers sam
[Image: Cn91r40h.jpg]
If I'm reading that correctly, the beam is currently set to 40mm?
40mm ish yeah, i called it offroad as maniflow refer to them as road or race, this is race one which isnt much much differant but both road and race ones can be fitted with cats still
My gti 6 would have passed a db test for the tracks no probs
Cams, Rallye door cards & gear links for £250? definitely interested in door cards as mine are cracked.
Team Cyril
Would you need it posting?
Cash on collection fella Smile
Team Cyril
Ok well im hoping to start getting it apart on saturday so will get the cams out
OK fella let me know when it'll be apart. i dont mind coming down and lending a hand stripping if it knocks abit off Wink
Team Cyril
I've inboxed you.
there's two manifolds pictured, which one is for sale?
Its the bigger one on the right chap, other ones for a 205
Post side skirts ? Pm me please
What make are the "aftermarket wishbones"
Interested in a deal for those and the ta technix. Do they come with top mounts?
When i say aftermarket i mean replacments from GSF, Ive got some roller wishbones that need some new needle bearings from.rich?
Regarding the torsion bars, what do you mean by 'one end bolt needs attention'?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
All clips intact on black masks? any more pictures of lenses condition?
[Image: 20gh7o0.jpg]
Just standard replacement is all I need. What's the condition of the ta's? Any pictures?
  Stage 3 hdi breaking, big spec!!! dr_jekyll 19 17,000 24-01-2019, 08:33 PM
Last Post: dr_jekyll
  BREAKING phase 2 xud 306 sedan bianca white Jamieh2013 56 26,197 15-12-2014, 07:52 AM
Last Post: Jonny81191
  Breaking ph3 xud huge spec stainless exhaust tdo4 Bosch pump fmic ect Danny2009 27 13,130 04-08-2014, 07:58 AM
Last Post: ct-hdi
