ABS light not working
Soooo i have just finished my 1.9 nad to HDI conversion on my ph3 estate. I have it running and driving with everything working apart from the abs light on the dash it doesn't come on atall it was working in the donor car and have changed the whole loom up to the wipers so using all the donor stuff apart from the pump but was fine before. If i unplug it from the abs unit i have the light come on the dash so bulb is ok. There were 2 boxes behind the bumper on passenger side would these have anything to do with it? hopefully you guys can point me into the right direction because its baffling me now.
Have you checked the abs for operation, is it working at all?
[Image: av5ym8.jpg]
Yea it still works just been for a drive and stamped on the brakes
Sooo does anyone have any ideas for the answer check light????
I aint got a clue mate, keep bumping and someone might answer Wink has the bulb gone??? its a silly suggestion but have you checked?
The bulb still works. When I unplug it from the abs pump the abs and handbrake light comes on the dash.
