my windscreen washer motor
right il keep it short lol
my washers and wipers stopped working if I pulled stalk to me but wipers would work if I pushed stalk up through the speeds, there is no noise from the motor at all so I removed the motor itself and its full of water.
this might sound stupid but should the motor be full of water or not?
Don't fully understand but the motor shouldn't be full of water. It's a common thing though as the drain holes block up and then fill with water.
I would guess a new wiper motor is needed
cheers iv edited it now hope it makes sense now
the motor is not water cooled. it should not be full of water...
Water in the motor may dampen the effects of its efficiency.
Screening the electrics for faults would be a good start. Remaining fluid in your fault finding will keep the ideas flowing.
/illgetmycoat
oh I don't like the sound of that I was hoping it would a case of replacing the motor
(02-03-2015, 10:29 PM)jayspug86 Wrote: oh I don't like the sound of that I was hoping it would a case of replacing the motor
I'm a tyro on these cars still....but..........I would suspect the stalk as they seem to fail according to the forum.......wipers work ok in the fast slow and intermittent position...........but don't work when the stalk is pulled towards you, the wash wipe mode....the washers don't work either, so there is a common fault, may be power to the washer pump and the wiper motor...........( does the rear screen wash work? ) ...........the wiper motor seems to be ok ( it works ) but the washer motor is full of water....which is probably a fault....a blown fuse maybe????  don't ask me which fuse it will be cos I still don't know!!
a basic wiring diagram for the wash wiper function would help..... Blush
are the stalks coded or just simple swap?
Wiper stalks just swap over. If you need 1 i will do 1 for £7 posted. PM me if interested, also have a wiper motor as well if need
right I took old motor off and wiper stalked worked as it should but don't when I put new motor on??
(04-03-2015, 04:44 PM)jayspug86 Wrote: right I took old motor off and wiper stalked worked as it should but don't when I put new motor on??
you took the motor off.... and it worked...
but didnt when you put the new one on?
exactly what part was working if there wasnt a motor plugged in?
as above the wiper stalk works when you pull it towards you but stops working when you connect washer pump back up
Are we talking about the washer motor, or the wiper motor? I'm confused. Huh
Relay I reckon
the stalk stops working when you reconnect the washer motor
how can I test relay
(04-03-2015, 06:50 PM)jayspug86 Wrote: the stalk stops working when you reconnect the washer motor
what part of the stalk works? how can the stalk not work? It only moves?
what are you controlling with the stalk that works? the washer jets?
im got try and be clearer for everyone Wink
original problem was went to clean screen one day and when I pulled the stalk to me it done nothing, the wipers didn't move and the washer pump made no sound.
I removed the washer pump and it was full of water
while the washer pump was disconnected I tried the wipers again buy pulling the stalk to me and it worked.
so I replaced the washer pump with a new one then when to pull the stalk again with new washer pump connected and wipers did nothing again but will wipers will work if I disconnect the washer pump again.
so to summarise the wipers will work if washer pump in not connected and stop working when it is connected
Smile
thankyou.... and i dont know what would cause that.
losing patients now lol
(05-03-2015, 12:30 PM)jayspug86 Wrote: im got try and be clearer for everyone Wink
Smile
Wow you proper went around the houses with the is post.
I'm having the same issue with mine. I've not tried replacing or disconnecting the washer motor yet.
Did you find out what the issue was?
Sounds like either the relay or a corroded wire not able to carry enough current hence it works with the reduced load when the washer is unplugged but not when it's present.
I'd also check the relevant fuses by substitution as sometimes they can break without being blown completely causing issues like this. My money would most likely be on a wiring issue though.
  Windscreen washer issue Iceman299 1 2,131 14-05-2016, 07:13 PM
Last Post: DeeTurbo
  windscreen washer reservoir pug306driver 3 2,746 05-03-2015, 12:35 PM
Last Post: Mattcheese31
  windscreen washers londondan86 2 2,690 29-04-2014, 10:35 PM
Last Post: londondan86
