Master cylinder change?
Quick question when changing the master cylinder, do people change the rubber seal between the master cylinder and the tank? If the master cylinder was in good working order with no leaks and it was changed straight away from one car to the next and torqued correctly? Just because the seal looks quite hard to remove with damaging the piston..
I've changed a few master cylinders for people over the years straight off scrap cars without changing the seals ( ideally I wanted too but the customers always right) without any failures.
  HDi 23.8mm Master Cylinder - Where from? Alan_M 3 3,261 07-09-2016, 02:33 PM
Last Post: Alan_M
  23mm Master Cylinder with 266mm Brakes MY95 18 10,974 16-04-2015, 01:42 PM
Last Post: MY95
  Hdi master cylinder tysonbully2k12 0 1,869 24-02-2015, 04:43 PM
Last Post: tysonbully2k12
