Tensioning timing belt
Basically I'm a tight fucker and am not buying the Peugeot tool to do it so how do you guys correctly tension your belts? I know how tight the old one was but is it really safe enough for me to just say "yeah that feels tight enough" or is there a way of doing it more accurately?
Arent the XU petrols tensioned by the spring in the top engine mount like the XUD's? :think:
Niall Wrote:is there a way of doing it more accurately?
Buy the tool lol
Dan! Wrote:Arent the XU petrols tensioned by the spring in the top engine mount like the XUD's? :think:
Nope. Got a separate tensioner above the water pump that you have to adjust.
What does Haynes say?
Dunno because I haven't got one! Just autodata which doesn't tell you how to tension it. Just tells you to do it lol
tighten it so you can only turn it 90* between finger and thumb
samass Wrote:tighten it so you can only turn it 90* between finger and thumb
Is that actually a serious answer? Would make sense as I actually did that when messing around earlier lmao
yep for realsies. tis what i've always been taught, by my mechanic housemate, my technician at uni, and my dad. they dont need to be tighter than that really, it'll just shag the bearing. if you find it squeaks a bit, then nip it up a little more, but i'd be surprised if it does
Ah fair play I will do that then. I know they whine a bit when too tight as I did that on my 106 lol
haha yep, done that too!
Difference is compared to the 306, that was easy. You could get into the engine bay on that thing to get to the belt lol
haha maybe in your 1.1 (right??) less room in a derv bay! through the wheel arch lol
Niall Wrote:Dunno because I haven't got one! Just autodata which doesn't tell you how to tension it. Just tells you to do it lol
I hope you do, because you still have my one!
Have I? I thought I gave it back? Will have a route around under the bed. Will be in the mess of sticky tissues somewhere I suppose....
This ^^^ i did mine this way last year and had no problems since
*Note that should be on it's longest run - 90* on the longest run...
Should have put this on here earlier for future reference.
The tensioner that comes in the kit actually has a marker to show when it's up to tension.
Bolt the tensioner to the block loosely, fit the belt and use a 5 mm allen key to turn the tensioner until the pointer lines up with the notch. Tighten the bolt and then turn the belt one full turn (4 turns of the crank pully). Check tensioner and re adjust if needed. Also need to reinsert your locking pins to make sure everything is still lined up.
edit; turn crankshaft pulley 2 turns, that will have turned the camshaft just once.
daddyfixit Wrote:edit; turn crankshaft pulley 2 turns, that will have turned the camshaft just once.
But only gone through half a cycle of the belt. Needs 4 turns of the crank pulley to turn the belt one turn.
  Timing belt Tensioner Bolt crazydave 5 3,430 08-05-2018, 10:59 AM
Last Post: crazydave
  Timing Belt with water pump kit mackat 13 5,130 24-04-2016, 06:36 AM
Last Post: mackat
  Timing Belt Kit paulgtt 7 2,991 21-10-2014, 08:22 PM
Last Post: miles
