Threads: 162
21
Car Model/Spec: 306 HDI Dturbo, Estate & GTI6
Given 23 thank(s) in 23 post(s)
Done a clutch change on my girlfriends 206 HDI the other month and now I can hear the O/S/F wheel bearing ever so slightly.
I think I've over tightened the hub nut to 450Nm instead of 325Nm, what are the chances of them being damaged and would you think if I undone them and torqued them to 325Nm would they be ok?
Going to be torquing them tomorrow after work.
Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
Depends on how many miles you've done over tightened and the quality of the bearing, I've got away with it before but it always needs changing within sort of 6 months.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Does jumping on a big bar until they're tight not qualify as acceptable?
Threads: 162
21
Big torque wrench at work. It's got a 3/4 inch fitting.
Threads: 10
Given 0 thank(s) in 0 post(s)
450 is what hub nuts on range rovers are lol a bit much for a small car I would say
