Wanted: PAS Return line
Long story but I need the return line for my power steering on my XUD Smile
[attachment=21475]
That's not a xud its a gti6. That's not a return line its the pas fluid cooler believe it or not. Some came with them some didn't. You can just remove and bypass. Easy as hell. Smile
(01-02-2015, 12:43 PM)bashbarnard Wrote: That's not a xud its a gti6. That's not a return line its the pas fluid cooler believe it or not. Some came with them some didn't. You can just remove and bypass. Easy as hell. Smile
I know but the pipe is the same, its a pic online and how do you bypass it? It was pissing out pas fluid
Follow it up to where it connects to the rubber hoses and join the 2 hoses together
(01-02-2015, 12:57 PM)Seb_Ryan Wrote: Follow it up to where it connects to the rubber hoses and join the 2 hoses together
Oh sweet I'll do that then Smile
Yeah as above just join the two hoses. Mine had a cooler with a tiny leak on it. Did away with it with the new engine and never had any issues!
(01-02-2015, 12:59 PM)Niall Wrote: Yeah as above just join the two hoses. Mine had a cooler with a tiny leak on it. Did away with it with the new engine and never had any issues!
Sweet Smile you need a small bit of joining pipe?
Yeah. So what you go is gut the cooler. Cut a good bit out and use that as the join. Wink
A PAS cooler on an XUD!? Whats the point lol? I'm sure I've never seen one on a ph3 until the GTi!
2 of mine had coolers. My current one doesn't. Lus two havnt. No idea why
(01-02-2015, 06:31 PM)bashbarnard Wrote: Yeah. So what you go is gut the cooler. Cut a good bit out and use that as the join. Wink
That's a good idea Smile I'll have a go at it Wednesday
Thats what i did, used the u bend for it
Will do Smile the pas pump is whining like a bitch now haha still very light steering though even though it's lost almost all its fluid  Confused
306s never have very light steering. Tongue Don't run it without any fluid though, you'll damage the pump.
(02-02-2015, 09:44 AM)Toms306 Wrote: 306s never have very light steering. Tongue  Don't run it without any fluid though, you'll damage the pump.
Getting some fluid today and going to try fix it tomorrow Smile
Never knew they had coolers, didn't realise it was something that got hot enough to need one.
  Wanted: Bosch fuel return banjo 306pc 3 2,712 01-04-2016, 06:02 AM
Last Post: Piggy
  Hdi injector return pipes Josh_Quant 3 2,326 02-01-2016, 06:57 PM
Last Post: Josh_Quant
  Wanted: K14 or T2 Oil return flange/pipe 306Puggy 13 6,336 26-04-2014, 06:48 PM
Last Post: 306Puggy
