406 hdi lower pipe
406 hdi lower pipe
Hi all!
Is everyone that's using the 406 lower pipe happy with the fact it touches the subframe? Just fitted mine up and it there's zero clearance, I'd imagine with standard engine mounts it won't last very long at all, am I missing something?!
Cheers, Al
Sorted. Trimmed as much as I dared off the turbo end of the plastic pipe, shortened the original joiner a little and 'relieved' the subframe around the lower engine fork. So much for things being a straight fit! Big Grin
What are you doing with the clutch or are you going to run the limited torque stage 2?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
I've put a new Valeo in it after discovering the 'super dooper Sachs berlingo clutch' is the same as a 306 item. I've had more joy with Valeo than Sachs in other cars hence my choice. I think jamma said 150bhp/250lb map, see how it goes....
Yeah just needs a little trim, i trimmed the edge of the bracket on the subframe too, just enough to give it breathing room.
  Lower air box pipe diameter? JTaylor2005 2 996 26-01-2016, 09:22 PM
Last Post: DeeTurbo
  Lower boost pipe options. bashbarnard 12 2,748 12-10-2015, 07:14 PM
Last Post: ccr24
  HDi lower intercooler pipe HDi--Power 5 1,578 05-12-2014, 07:19 PM
Last Post: DeeTurbo
