hdi injectors
hdi injectors
So im in need of new injectors, found a pic online with what cars i can get them from,
Does it matter what year car?
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
No, the year doesn't matter, although newer is more likely to be lower mileage, as long as you have a full set of the right part number.
044s also seem to be more prone to ticking than 076s.
lol that picture looks like something i did
http://306oc.co.uk/forum/showthread.php?tid=5399
GTI6 Info
So go for 076's? Il try and find some cheap as mine are getting worse and worse.
Cully i found it on google and stole it :-D
062 and 076s as far as im aware are both less prone to being 'tappy'
[Image: av5ym8.jpg]
So i found 2 sets
1st set from 307. Look completly different
2nd set from 406, there 062's.
2nd set
Some 307s came in siemens varient
Yep, as above, the top set are Siemens, easily identified by the leak off pipe being on the side rather than top.
Thought they looked weird,
Might try and get the 406 ones cheap
Only thing is i dont know what mileage and 406s are usually high milage
