how much air :O
how much air :O
Shocked
so i've had my car on the road since monday, thought the tyres felt a little low so checked them this morning.....one of the front ones had 42psi in and the other had 47psi in :O btw I'm running cyclone with 195 50 15's lol talk about overinflation!
I normally run between 35-38 but pretty sure that's wrong lol
32 is "industry standard".. if you put that in most passenger vehicles it'll be fine. But there are a few which run well outside that, so it's worth checking..
As for cyclones with 195/50's on, I generally run the same as Matt, I think my fronts are 38 and the rears 36. Depending on the tyre, they do seem to want a lot of pressure to hold profile.
FYI the stock pressure for 195/55/15 on a 306 is 37 PSi..
Thanks given by: Bassman85
(15-01-2015, 08:27 AM)Jonny81191 Wrote: 32 is "industry standard".. if you put that in most passenger vehicles it'll be fine. But there are a few which run well outside that, so it's worth checking..
nice one, cheers for that mate andy to know, was going to go for standard 32-34 but i'll revise that Wink
