11-01-2015, 02:54 PM
Hi my outside temp sensor is showing - - -. has done since I got it. Presumed since my wing mirror was held together with electrical tape It was the sensor so replaced the mirror and still the same. Any ideas?
Exterior temp sensor display
11-01-2015, 03:34 PM
Door wiring either broken or corroded plug, had same issue and i cleaned the door loom connections
11-01-2015, 04:28 PM
Cheers will have a look when I get chance again
12-01-2015, 03:52 PM
Okay cleaned it and it now shows a reading. Reading was correct for a hour or so but then it went mental telling me it was -15 and keeps moving about. Fault or just need more cleaning?
13-01-2015, 02:24 PM
Will either be that or a damaged wire.
13-01-2015, 02:25 PM
Took it off and cleaned it a bit more. Noticed the threads on the screw bit were buggered and when I thought it was tight it was only half on so gave it some persuasion and now jobs a good one. Thank you
| Drivers exterior door handle | chylledapps | 0 | 1,677 |
26-07-2015, 04:54 PM Last Post: chylledapps |
| 306 radio display problem | Earnest Lee | 0 | 1,844 |
07-06-2015, 12:25 PM Last Post: Earnest Lee |
| exterior from Ph1 to Ph3 | vandalzd | 7 | 4,446 |
06-05-2015, 12:15 PM Last Post: maxzy |
