Wanted: PH2 AUX setup / A/C pump
I need a A/C pump and a PH2 AUX setup.
No so worried about teh auto tensioner, but need all brackets and also if the PH1 PAS pump doesn't fit I'll need the PH2 pump please.
A/C compressor ideally sealed from the elements and in full working order not long removed, else waiting to be removed from the car and still sealed.
Ideally also would be the fittings from it to the high and low pressure lines which can happily be cut after a short length if it's ally.
Appreciate the vagueness of the request.
So ideally someone around Warrington/Liverpool/Manchester area so I can come take a look and remove ??
  Wanted: Saxo pas pump setup Paul_13 0 1,283 02-05-2016, 08:31 AM
Last Post: Paul_13
  GT2052 bolt on setup and Bosch pump Nathan1305 2 2,704 27-09-2014, 09:55 AM
Last Post: Nathan1305
  Wanted: 11mm bosch pump setup maffy 2 2,388 05-02-2014, 09:37 AM
Last Post: Piggy
