Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Okie dokie lovely. And really take the engine out?? -_- thats a bit of a pain for me as I have no where to even put it when it comes out haha.
Threads: 371
29
Car Model/Spec: ford fiesta
No you dont have to take the engine out to do a head. What engine is it??
Threads: 9
I wouldn't say plenty of room personally and as the subframe has to come out for access, all thats left holding the engine in is the gearbox mount in the end. I know how I'd do it if I had to do it again.
Threads: 72
Car Model/Spec: 205 1.9 D Turbo (Full Gti Rep)
Given 1 thank(s) in 1 post(s)
take the top mount off and pull the engine towards the front of the car.
There will be enough room to do the job then
Threads: 117
119
Given 105 thank(s) in 105 post(s)
Really shouldn't have to take the subframe off, all you need to do under the car is disconnect a couple of brackets, oil hoses and exhaust downpipe.
Do you have some of the E sockets, the ones that look like female torx bits? The headbolts are E12 or E14. Nothing else unusual in there i can think of off the top of my head...
Threads: 41
28
Given 86 thank(s) in 85 post(s)
never touch the subframe, just lift it straight out the top.
Threads: 0
Car Model/Spec: Peugeot 306 2.0HDI 2001 AC
Hi Just one small tip.
While rocking the engine back and forth properly supported by your favorite jack.
Don~t overdue to avoid damage to the steering hooses in the bottom.
Other then that go calmly step by step it should be fine in the end. ;-)
