Threads: 72
0
Car Model/Spec: 205 1.9 D Turbo (Full Gti Rep)
Given 1 thank(s) in 1 post(s)
15-12-2014, 09:50 PM
(This post was last modified: 15-12-2014, 09:50 PM by pugtk.)
Hi There,
I've stripped my head down this evening.
However, I just cant seem to get a grip on the the valve stem seals to remove them.
Is there any method to remove these.
Is it a case of force?
Threads: 34
8
Given 7 thank(s) in 7 post(s)
Long nose pliers will do the trick, just put one end down the middle and the other on outside and not too far in, twist and pull
Threads: 72
0
Got them off
Any way to get them on without damaging the rubbers?
..haha
Really should but the correct tool
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
Tap them on with a small socket?
Threads: 72
0
Thanks,
I may just look for a socket that catches the collar of the valve stem.
The only one I could find would have just ripped the rubber.
Garage Clean up needed ..haha
Threads: 41
3
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
Sat and watched all the videos last night. Quite entertaining and informative.
Thanks for doing them.
