outside air temp inaccurate
So ever since i bought the car its never worked properly, it always displays a temperature but lets be honest its not -23 degrees outside (thankfully).
Now i have changed the passenger mirror for another one i had spare, but still no different
Then i swapped the actual clock unit itself in the hope that there the only two parts to make this work.
I know its not faulty wiring in the door loom otherwise it wouldnt display at all.
Mirror and clock both spares i had and unsure of there condition just kinda hoped that i wouldnt have two faulty units.
Anyone shed any info/light on what to check next
Cheers
[Image: av5ym8.jpg]
Could easily be faulty wiring. If its a broken wire causing high resistance, the temp sender will give an incorrect reading.
Yeah true, sometimes its believable bust most of time its clearly wrong. Bit annoying really.
Will have a look at door loom, not gonna disturb it too much though incase stuffs gone brittle
[Image: av5ym8.jpg]
Have a look for corrosion on the mirror plug your on the door loom plug.
Good shout dee, will have a look there too
[Image: av5ym8.jpg]
open the passenger door with the ignition on to see if the value changes if it does its a good indication of the door loom fractured but not broken
Soo....
[Image: DSC_0621.jpg]
[Image: av5ym8.jpg]
yup that would do it Smile
  Inaccurate fuel gauge. Pebbles167 6 2,942 23-08-2014, 10:38 PM
Last Post: Dangti6
