Rear Brakes Rubbing?
I have a disc rear beam, changed the rear pads and discs March this year and they were absolutely fine.
In my MOT the Handbrake isn't the best (as you all know on 306's!) but the cables stretched a lot! has to be 16% effective to pass, mine got 16%.. Haha!
When I set off in the car with the handbrake off it feels like the car bogs right down at the back as if the handbrake is on and you're rocking the car on the biting point?! any ideas on why this is? possibly because the handbrake cables stretched a lot and the rear pads are stuck on?
cheers in advance
1.9 diesel Phase 2 - scrapped
1.8 meridian Phase 3 - going strong!
sticky calliper piston? how much travel is on the handbrake? maybe over adjusted it? . .
More than likely seized/sticky caliper sliders. They seize up so quickly on 306s, I don't do much heavy braking which means the rears aren't used often so mine would tend to start sticking roughly every 3 months!
(09-12-2014, 10:14 AM)Mattcheese31 Wrote: sticky calliper piston? how much travel is on the handbrake? maybe over adjusted it? . .
The handbrake is pretty ineffective! there's about 13-14 clicks on the ratchet before anything happens haha!
(09-12-2014, 10:57 AM)Toms306 Wrote: More than likely seized/sticky caliper sliders.  They seize up so quickly on 306s, I don't do much heavy braking which means the rears aren't used often so mine would tend to start sticking roughly every 3 months!
So just a strip down and clean maybe? that'd do the job!
  Nasty vibration coming from the rear brakes johnny625 9 8,759 12-04-2020, 10:26 AM
Last Post: johnny625
  What Rear Brakes Do I Have cateraxe 7 5,077 07-11-2016, 10:19 PM
Last Post: miles
  Rolling road - split driveshaft boot and binding rear brakes reduce power on graph? MY95 28 13,595 23-03-2016, 12:33 PM
Last Post: tigerstyle
