Front brake or brakes making ch - ch - ch - ch - ch sound
On my other car not a peugeot the Front brake or brakes making ch - ch - ch - ch - ch sound
The proton wira front brake or brakes making ch - ch - ch - ch - ch sound. Only does this when hard braking. When normal braking or driving along there nothing.
if the noise is a *ch - ch - ch - ch - ch - ch - ch * kind of sound...you probably have a bent backing plate or something stuck behind.
Old vented front discs with newish pads.
I took all the brakes of all apart. The pads are fine but I rough them up on the concreate. The calipers push in fine on both sides also slide fine. The discs had scratch lines on the passanger side you could feel with your nails. Then on the driver side it was starting to go there as well.
There nothing catching anywere at all checked both sides.
Ive put other discs on with other pads but still that noise.
Those are the scratch lines on the discs I have noticed. There not cracks but scratches.
New disc fine
[Image: DSC01437.jpg]
Old disc scratch lines
[Image: DSC01436.jpg]
New disc and old disc
[Image: DSC01435.jpg]
Old discs with scratch lines
[Image: DSC01438.jpg]
Mine did this when I had 13" alloys on because the caliper was catching the wheel when braking.
Stage 2 XUD Sedan
strictly_derv Wrote:Mine did this when I had 13" alloys on because the caliper was catching the wheel when braking.
Ive gone from 14inch to 17inch alloy wheels. But its been fine for 40,000 to 50,000miles so far. But only recently this scratching on the discs has started on both sides. Also that noise as well has started to.
But I know what you mean about having smaller wheels.
That's not a new disk...
Is it not warped?
Could be warped - seems as though it's 'catching' when it's applied
Also putting it in the right section would have helped....
  Disconnecting rear brake lines at the front Iaitoo 21 9,430 04-06-2016, 08:22 AM
Last Post: pug306driver
  Identify these front brakes.. Dazecoop 14 6,938 21-12-2015, 04:24 PM
Last Post: Elfyno
  Where to find new front brake callipers quite cheap? MY95 31 9,898 25-10-2015, 04:36 PM
Last Post: Jonny81191
