Threads: 1
Hi there! The rev counter on my s16 has just stopped working. At the same time this has happened the car will barely run above tickover. Do you think the ecu doesn't know what the revs are therefore it doesn't know what fuel and air to feed into the engine? Where is the sender for the rev counter? Can't find it in the Haynes manual.
Threads: 591
54
Speed sensor in the diff provides a speed...not RPM!!
I can't recall if the S16 has a crank or cam sensor, but it's most likely to be one of those and it would indeed have an influence on the cars ability to run.
Threads: 42
28
yes they did.
map is onboard the ecu.
rpm is direct from ecu, does not rely on a sensor directly to drive the tacho, however without a tdc thr engine wint run anyway.
sounds like possible vac pipe issue, theres lots on them.
