Threads: 4
Car Model/Spec: 1997 306 1.6 8v daimond
30-11-2014, 08:25 PM
hi guys
um... i was gonna take my gf and dog to a drive when i walked to the car i saw that all the lights on the dashboerd are on as if i turned the ingniton on...
i tried starting the car and nothing getting no spark and no fuel pumping in to the injectors... i checked all fuses and nothing apart for one which when i pulled it out all the lights turned off and the radiator fans started working but still cant get the car to start... any help? PLZZ!!
Threads: 11
30-11-2014, 08:35 PM
(This post was last modified: 30-11-2014, 08:36 PM by vincent1.)
theres a wiring loom connection by the radiator down one side im sure it unscrews/un plugs remove this and check all the connections are fine im sure ive read this plug gives issues?
81
Isn't this the one that also catches fire and has resulted in peoples cars burning out?
Threads: 371
29
Car Model/Spec: ford fiesta
Never heard of that problem before :0
81
Yes. I'm fairly sure there is a thread about this being a serious fire risk. I'll see if I can find it.
Given 81 thank(s) in 77 post(s)
Correct, it can in some instances cause fires. You need to split that plug by the rad and check it for corrosion. If there is any it can be cleaned up with some lighter gas. , clean up all the pins and put the plug back together then cover it in white grease to prevent water ingress.
Threads: 371
29
Scary shit. I know mines ok as ive just swapped the engine out but ill check my other halves one. Specially as we have a little one strapped in to it all the time
