XUD11 2.1TD tightening torques
Hi all
Hoping someone is around to help out
My autodata has gone corrupt for some reason...
I need tightening torques for the head on a XUD11
As in, manifolds, cam carrriers etc
be a huge help! many thanks! Smile
Hope this helps. Couldn't work out how to print screen straight from auto data
Cylinder head
Maximum bolt length: 151,5 mm
Tighten: 20 Nm
Tighten: 60 Nm
Tighten: 180°
Other engine tightening torques
Main bearings Renew bolts/nuts: No
Main bearings Stage 1: 15 Nm
Main bearings Stage 2: 60°
Big end bearings Renew bolts/nuts: Yes
Big end bearings Stage 1: 20 Nm
Big end bearings Stage 2: 70°
Oil pump to cylinder block : 18 Nm
Sump bolts : 16 Nm
Sump drain bolt : 30 Nm
Flywheel/driveplate : 48 Nm Autodata Note
Clutch pressure plate : 20 Nm
Crankshaft pulley/damper centre bolt : 40 Nm+60°
Camshaft sprocket/gear : 43 Nm
Camshaft carrier/cap : 25 Nm
Camshaft/rocker cover : 8 Nm
Inlet manifold to cylinder head : 23 Nm
Exhaust manifold to cylinder head : 20 Nm
Injector/clamp : 90 Nm
Injector pipe unions : 23 Nm
Injector nozzle to holder : 130 Nm
Fuel/injection pump sprocket/gear : 50 Nm
Fuel/injection pump flange : 20 Nm
Fuel/injection pump mounting : 20 Nm
Glow plugs : 25 Nm
you star buddy!
rep'd Smile
Glad to be of help mate.
Ive changed the title of this just so others can find it in the future Smile
Yeah good plan!
I did a lot of searching on the net earlier and couldnt find it anywhere etc...so hopefully a google search will end here!
  lower height pistons xud11 of 1 mm niciou 3 7,495 01-03-2018, 07:44 PM
Last Post: niciou
  How To - 2.1TD Swap / XUD11 Fitting Dum-Dum 101 161,688 28-07-2017, 12:18 PM
Last Post: rachaeljf
Wink The judge and its xud11 Sambo the bodger 37 29,546 24-06-2017, 06:04 AM
Last Post: bashbarnard
