Turbo Back Exhausts?
Hey all. When having a turbo back exhaust what would be a good size to go for?
Also on turbo back exhausts will this part need fabricating?
[Image: %24_57.JPG]
Thanks Smile
If you are using a standard turbo, I would just go from that flex joint back.
2.25" is standard I believe, so 2.5" would be a good improvement. 3" would be a bit overkill unless you are hunting for big bhp with a bigger turbo
Fair enough mate, Cheers Smile
I suppose a nice mandrel bent 2.5" would probably flow a lot nicer anyway than a 2.25" crush bent muffled setup anyway haha.
from my limited diesel knowledge you want to get everything out of the turbo as quick as possible. So ideally youd have no exhaust but in reality the bigger the better. 2.5" is the right size to go for in reality.
What you want to go for is the decat, standard centre pipe and then remove the backbox and replace it with a straight pipe or a cut down centre pipe.
The manifold elbow part you posted a picture off doesnt need changing.
Nice. I was thinking along the right lines then haha Smile All good.
Thanks guys Smile
No Worries. Hooroo!
[Image: Screen%20Shot%202014-03-13%20at%2018.15.14_0.png]
All about 3" though I can't take credit for the 1 on the estate. It sounds epic
Just a warning, if you go too big it can be counter-productive, quite aside from being pointless. Besides, the bigger you go the more expensive, heavier and more of a pita to fit it becomes. 2.5" has more than enough flow for stage 2.
  All the gubbins between turbo and back box Orta 5 3,407 05-11-2015, 09:53 AM
Last Post: Toms306
  stainless steel exhausts procta 8 4,894 02-03-2015, 01:38 PM
Last Post: Kezzieboy
  Estate Exhausts LewisG 5 3,923 07-12-2014, 08:47 AM
Last Post: Razorback_Rob
