Service box help.
I need item 3 from Peugeot but I do belive this is a specific type for the wrong rad. I need one with one outlet on the top. I cannot find it on service box at all. Someone help please!! [attachment=19908]
erm, what?
Not sure what you mean mate, have you got a pic? This one looks different though...
[attachment=19911]
Basically the common phase two setup on the xuds has a header tank of which one pipe goes to the top of the part. The phase one type rad with the header tank attached to the rad does not have this pipe and therefore does not need the two outlets just the one.
aH OK, i'LL HAVE ANOTHER LOOK
Edit - Oops. lol
you mean the small pipes on the top heater matrix size?
This is my current one. The pipe on the left had been skillfully blanked. They do one with out it so there is only one pipe on the top. Just cant find it. [attachment=19915]
pug do the correct blank for them as my nad has a blank from factory i have the part number in my car if you want to fit a pug blank instead (mine rotted throgh the top car had done 225000 miles though) mines a ph1 with built in header tank.
Id love the number for the blanj then.please. Ill order the blank and another one of these as I think this ones broken.
part number 0245 16 is a rubber blanking plug about 1 inch high fits with one jubilee clip i did bodge mine like yours.
roughly £6.34 inc vat for two.
see post 10 in this thread uses same bung.
http://forum.205gtidrivers.com/index.php...pic=115854
I broke this part (1336.G4)when I took the engine out my 306. It was the only part that broke so I was being careul. When I took it off the Xantia engine I was doubly careful but it still broke! I got a new one off Ebay.
Anyway, the Xantia one had a bung over one of the outlets as you can see here:
[Image: waterflange.jpg]
Thanks for the part numbers the ones with 2 are 1336 g6 I think. Yours only has one. Ill get onto my mate at pug tomorrow and see the price. Ill also check ebay Smile I will rep once im on pc later
