Timing tool pin set
I'm looking to do a Cambelt/water pump change on my 6 and was wondering if anyone could provide me with either a link to a set of timing pins I will need or, provide me with maybe drill bit sizes? Ie cams need 6mm bit to lock in for eg
Thanks all
Dave
i made my pins from
2x 6mm shouldered bolts with the threads cut off
1x 9mm ish pin punch filed/sanded down to the correct size using a drill to spin it to keep it round
camshaft locking tool made out of 20mm ply
now i can lock the centre bolts to there correct torque without stressing the locking pins Wink
[attachment=19906]
[attachment=19907]
Nicely done there cully very impressive, how did you make your camshaft locking block?
scribed two arks the same diameter and distance apart as the cam pulleys with a compas, cut it out with a jigsaw drilled the hole, then cut the section out in the centre
Cully has done it right!!!
I think cully should make a set and sell them to me ..................Smile
  head bolts tool Chris_90 27 16,443 21-09-2013, 10:35 PM
Last Post: Danny2009
