Brake fluid
Brake fluid
Hi,
Am in the process of uprating the braking system on the rallye
It has Ferodo ds2500 on front with unknown discs but they have a fair amount of life in them so they can remain.
I am currently rebuilding my rear calipers and they will be going back on the car with Ferodo ds2500 roads and gsf brembo discs.
I have bought some braided hoses as well
Anyway, can someone suggest a good brake fluid? I was going to just go with halfords 5.1 but I have read that some dot 4 out performs some dot 5.1 so what do you all recommend
Alan
5.1 is in general better than 4. Break fluid is so cheap anyway that there isn't much point in getting the cheapest alternative.
I've had good results with Motul RBF-600, but i've also had equally good results with a local budget car-parts chains "race" brake fluid, only downside is that it's so clear you can hardly se the level in the reservoir :p
Here's a table compiled by users on a racer forum i visit, prices are in Swedish krona.
Torr kokpunkt = Dry boiling point, Våt kokpunkt = Wet boiling point
[Image: 2013-07-30-08-08-56_bromsvatska.jpg]
The one i run today is the Biltema Race 5.1
Ate blue dot 4 is great stuff!
Halfords DOT5.1 has always been fine for me and taken whatever I can throw at it on road and track. Cheap with a trade card too.
Remember that it's important to change the fluid fairly regularly - at a minimum annually would be sensible if you're doing regular trackdays - due to the dramatic reduction in boiling point when the fluid has absorbed moisture (the so called "wet" boiling point)
There are certainly better fluids out there, but you'll likely find that DS2500's will overheat before the fluid does. Good pads though as a road-track compromise and I loved them on my 205 Smile
I has trade card! Will just go for the halfords stuff
Ate superblue is cheap and decent, but then again regular changes are the most important thing, even a regular flush with a factors cheapest is better than leaving your super-race fluid in for 2 years.
cheers, ill stick the halfords stuff in! at the moment the entire rear braking system seems to be in a mess
  Best brake fluid and pads? JTaylor2005 19 9,745 19-08-2016, 08:09 PM
Last Post: Pgtips
  ATE v Pagid dot 4 brake fluid 306rhys 1 2,919 28-08-2015, 10:08 AM
Last Post: PartyJas
  Brake fluid circulation hennus 5 3,426 12-03-2015, 10:49 PM
Last Post: Niall
