Ignition Feed Near Drivers Vent
Where do you guys get your ignition feeds from near the drivers vent for boost gauges etc...
Do the headlight adjuster switch etc have one?
Earth isnt a problem as there is an earth with loads of wires to it just behind the accelerator pedal..
Anyone?
Cheers
Chris
You can use the live feed to the sidelight switch on the indicator stalk. Depending which wire you connect it to then you can have it so your boost gauge lights up when you put the keys in the ignition, when you turn the sidelights on or when you turn the headlights on... Smile
No that wouldnt be any use to me cause.its just black otherwise lol silly smoked gauges
Re-read what I wrote, specifically the second part Doh :think:
lmao
Team Orange Engine Bay
Oops.. yep im a retard
  Drivers vent pod puglove 6 4,897 06-05-2013, 04:43 PM
Last Post: Tyronnster
  ignition back feed zx_volcane 4 4,128 01-05-2012, 08:28 AM
Last Post: zx_volcane
