Threads: 85
8
Car Model/Spec: E90 330i
Given 15 thank(s) in 15 post(s)
I refitted my cat back on the car today and noticed the bolts have been replaced with a general m8 thread.
My question is, how tight shall i do it as they have a spring? Would seem counterproductive to do them up too much. At the moment i haven't used the springs and just used nuts, the exhaust is vibrating a fair bit lol
Thanks
Threads: 117
119
Use the springs, they allow the exhaust and engine to move independently, it's a fundamental part of the design. Tbh i'd be inclined to just buy a new fitting kit, they're less than £15 from the motor factors and you can almost guarantee the fire ring is knackered.
Threads: 85
8
Thanks for te reply, i'll fit the springs on when im back at college. Shall i just tighten the bolt up until the thread stops or is there another way?
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
No, the wire gasket which u should replace as well moves and compresses but if you totally squash it, it doesn't do its job, just tighten it up equally on both sides, start car up, if it leaks tighten it a bit more
Threads: 85
8
Awesome, thanks. Just hoping the old fire ring comes off easily
Threads: 87
48
It'll be fine, just get a screwdriver behind it
Threads: 85
8
I've had the car up on the ramps at college for the past 3 weeks due to exhaust issues lol
First decat came loose, backbox had a leak so did a temp fix, replaced mid/back box, put original cat back on and now got to fit a new spring kit loll
Atleast it's not costing me garage fees! Lol
Threads: 581
195
A new fitting kit is £8 from ECP. Just make sure you get some copper slip on the fire ring otherwise after you pull away about 3 or 4 times, it will squeak like a right bastard.
Threads: 85
8
It's £11 from peugeot, is it worth buying from a dealer do you reckon, or shall i just get it from ECP?
And thanks for the tip, i dont fancy messing with the exhaust again after this lol
So there's no actual guideline on how tight the nuts have to be, just as long as it doesnt leak?
Threads: 591
54
With the kit, you tighten till they are tight
Threads: 581
195
Ah if its only £11 from pug, do that. Pattern fire rings are renowned for falling to pieces unless your lucky enough to get a good one!
Threads: 386
87
There is a torque setting for them iirc. It's not much though, like 30Nm. I've not got the Haynes to hand atm or I'd check.
Threads: 581
195
(25-10-2014, 07:15 PM)Toms306 Wrote: There is a torque setting for them iirc. It's not much though, like 30Nm. I've not got the Haynes to hand atm or I'd check.
alternatively, just tighten them up to the end of the thread. Sorted.
Threads: 386
87
Hmm, I still prefer torqueing things to perfection.
Threads: 85
8
25-10-2014, 07:18 PM
(This post was last modified: 25-10-2014, 07:19 PM by Iceman299.)
(25-10-2014, 07:01 PM)Piggy Wrote: With the kit, you tighten till they are tight
I snapped the one bolt by tightening it too much lol
the other one had already been changed by the previous owners for a generic thread
Atleast i got a new cat, mid section and D turbo backbox for £90 from ECP
Edit: yeah i'll be checking torque settings and doing them up right this time
Threads: 591
54
I guess its about feel. They are small threads
