Threads: 61
4
Given 6 thank(s) in 5 post(s)
I'm looking to swap my ph1 xsi (with s16 engine) to a xud because as a petrol it's a bit expensive to run. I know everyone is going to say just buy one but I've had the car for 4 years now and have grown quite attached to it and it is a clean ph1 and I know it's a good base car.
I know what u need parts wise but wiring what do I need?
Engine loom to the plugs down near the radiator.
Do I need the loom all the way up to the wipers?
Can I just plug a set of clocks in and everything will work?
Im not going to go big power just as a daily so will probably just run a bosch and a t2 if anyone has an engine ;-)
Threads: 80
3
Car Model/Spec: hdi estate bus cherry red hdi
Given 2 thank(s) in 2 post(s)
James lines aka (jimbo) had rebuild xud lump for sale don't no If he still has it
Threads: 591
54
Yeah you want just the engine loom.
Also need to swap the filler neck (or remove the restrictor) and swap pump pick ups inside the tank to xud pickup. Also thus need to remove all the petrol lines and replace with XUD ones (may some carbon canister crap to remove too)
Swap the clocks to ph1 dt clocks. Think you may need to run the speedo cable through though...not sure if the ph1 xsi is cable or sensor run.
Shouldnt have any issues with subframe but I ran into a problem with the gear linkage mount was an inch further back on mine...but I converted a ph3
Threads: 202
58
Given 29 thank(s) in 28 post(s)
You might need to swap the rad too, depends on your current setup.
Threads: 61
4
The car did originally have an electronic speedo but when I converted it to a s16 I ran a cable through so got a choice on what way I want to run it. Engine will drop straight in on the standard mounts as it's still an xu engine and also I'm pretty sure linkages will be ok as they look the same as the xud's I've had.
What issues could I come across on the radiator?
So I only need the wiring down to the radiator then??
Threads: 591
54
You wont find ph1 dturbo clocks that run electronic iirc
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
(12-10-2014, 10:08 PM)Piggy Wrote: You wont find ph1 dturbo clocks that run electronic iirc
There's both types, cable driven is only the really early ones 93-94
Threads: 87
48
(12-10-2014, 10:47 PM)Piggy Wrote: My 96 had cable ![Tongue Tongue](https://www.306oc.co.uk/forum/images/smilies/tongue.png)
That's the extent of your phase 1 knowledge then I take it?
Threads: 34
8
Given 8 thank(s) in 8 post(s)
My 95 ph1 had electric, seems to be random lol
