best fmic or best place to get a fmic kit?
I suffer alot of heatsoak in 4th and 5th gear in my td04 9mm. Looking a fmic kit but dont want to be buying bits i really dont need. The car is a ph2 if this helps and i will be looking to upgrade to 11mm pump in the near future.
Any links or help appreciated.
Not sure there is any difference between phase 1 and 2 that makes a difference between what stuff you need to get. Presume youre already running a bosch. There isnt a ready to bolt on kit as such unless you can find one second hand. All the parts are sourced individually and mostly from ebay. Most people go for a 2.25" setup. You dont need a massive intercooler to do the job. Often OEM ones from other cars will be super cheap.
  205 XUD FMIC pugtk 1 2,496 05-02-2017, 06:42 PM
Last Post: bashbarnard
  Fmic question blinkyeatu 6 5,050 09-08-2015, 07:45 AM
Last Post: blinkyeatu
  FMIC on ebay craig306 0 2,074 04-08-2015, 02:46 PM
Last Post: craig306
