Rear beam options
Hi
I'm thinking of changing to a gti-6 rear beam. Currently mine is non ABS drum brake set up. Can I swap to a disc beam easily or would I be better sticking with a drums?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Just need to get disc brake handbrake cables and be prepared to fiddle with the brake lines a bit Smile
And steer clear of abs beams I take it?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
No, its only a couple of sensors and abs rings
Just cut the abs sensors off. Rear disc beams are very rare without abs
Excellent, cheers boys. Will a xsara vts phase 2 (2004) fit?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
currently in the same boat got myself a vts beam im stripping at the moment, as its gonna go on a non abs phase 1 can i ditch the compensator spring valve for a t piece to split the lines?
  Rear beam ...the good and the bad Mighty306 35 31,573 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,431 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 16,001 18-03-2019, 03:40 PM
Last Post: MOK
