Electric mirror
Electric mirror
Hello, I've recently purchased a blaze 6, unfortunately the drivers side electric mirror is not working.
On further investigation I see the switch is only working the passenger side so needs replacing. Which isn't the problem.
I've manually sent power to the mirror with a power probe the motor is working but I'm assuming the worm gear is dead as there is no movement in the mirror.
Now when looking for a replacement what exactly will fit? Mine is a 97 R registration. Will any year fit? 3dr/5dr?
Just need to know what to look for.
Regards
Russ
Any will fit yes. I have some in south yorkshire if you are close
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Many thanks for the reply.
I'm miles away but thanks for the offer chap, there's a couple of the well known auction site as I'm still building posts on here to use the classified sections.
  Electric mirror's Mumford54 2 703 08-03-2015, 03:20 PM
Last Post: Mumford54
  Electric window/mirror switch differences ginge191 8 2,313 11-02-2014, 02:37 PM
Last Post: deggerz
