inlet manifold
Am I just being dumb?
I've ebay searched for a 406 inlet manifold to start a set up for an FMIC but the inlet manifold looks remarkably different to the one in the guide on here am I looking for the wrong thing? I've typed in peugeot 406 diesel inlet manifold
Cheers.
You're probably finding XUD mani's rather than HDi ones? It's only the 110HDi elbow you need as well, the mani itself is the same.
Im a complete novice at intercoolers so guidance is needed ha ha, so my inlet is the same I just need the 110 hdi elbow?
Yep that's right, the elbow just bolts on, but our '90' elbow faces down to the turbo, where the 110 elbow faces forward towards the FMIC.
Have a look in the guide section mate, several threads explaining this down to the last detail.
OK so after a bit of digging around on the net I've noticed lots of comments on removing air con? ? Can I not keep air con if I inter cool?
you can keep it or bin it its up to you
Removing the standard cooling fans and replacing them with slimline fans should give you enought room to fit a fmic.
Unless you where planning on fitting a huge intercooler, then you might need to remove the aircon rad as well. I'm in the process of gathering the parts aswell and would like to retain the aircon, but havent tried my intercooler for size yet.
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
As above, slimline fans will give you plenty of room for the fmic. It's pipework routing that's the challenge if you want to keep your aircon, there are very few places it can go.
Also if your looking for the Inlet elbow from a 406 give me a ring at work (autobreakers - 01432 361679) I'll do you one posted next day for £18 inc VAT just ask for Matt when you ring Smile
Team Cyril
  inlet manifold pug306driver 6 4,783 11-01-2019, 10:31 AM
Last Post: pug306driver
  Inlet manifold gasket dr_jekyll 2 2,841 04-05-2017, 07:55 AM
Last Post: dr_jekyll
  inlet manifold removal tysonbully2k12 25 14,621 09-05-2015, 01:06 PM
Last Post: tysonbully2k12
