Beam upgrade, which size discs and pads?
Mot time and I need discs and pads on the rear.
Had the beam changed years ago but not sure what it was off. I believe an sxi, can anyone see from this what size I need or if they are In fact off the sxi cheers for help
[Image: gahu5yby.jpg][Image: yta4a3ug.jpg][Image: ene9a5uq.jpg]
Iirc they are all the same Smile
Gti/sxi? Or sxi/dturbo? May well be it's just I have bigger calipers on the front. I'll have them off to measure up tomorrow. Cheers piggy
alll 306 rear disc's and pads are the same the piston sizes on the calipers are different tho
They're all the same on the rear, so doesn't matter too much.
Cheers fellas
247mm solid discs on all 306s...and 106s, and saxos....PSA just bulk bought them I think. lol
... but not 205's and 309's which use a different offset rear disk compared to the later cars (same diameter and thickness though)
  New pads and fluid, possibly discs. Pebbles167 23 11,847 30-04-2015, 12:45 PM
Last Post: adam b
  Mintex discs and pads opinions Nathan1305 16 8,819 13-03-2015, 02:29 PM
Last Post: PartyJas
  OEM discs and pads thebluepearl 5 3,343 01-08-2014, 11:21 PM
Last Post: thebluepearl
