Bens bosch conversion dont use the wrong key!
#91
Ben Jay Wrote:if this is the case im going to kick myself!
i just spoke to the garage that i dropped it off at to see if they had any idea and they said they didnt and didnt want to mess about with it.
so the hours labour they did for me yesterday im not going to be charged for as they know im in a pickle!
If they do try to charge you tell them to f*ck off since they looked at it and said that there wasn't a problem and that everything was correct...................clearly they didn't have a clue!
Team Orange Engine Bay
mark_airey Wrote:Tell them to f*ck off for the hours labour since they looked at it and said that there wasn't a problem and that everything was correct...................clearly they didn't have a clue!
Ben Jay Wrote:so the hours labour they did for me yesterday im not going to be charged for as they know im in a pickle!
Come on Mark, read it all properly! Tongue
Dan! Wrote:Come on Mark, read it all properly! Tongue
I did, after I clicked submit I re-read mine and then edited it, read my post properly Tongue
success it runs.
however now it has no oomph had my foot flat and nothing seemed to happen.
and ideas?
Connect the throttle cable?
Ben Jay Wrote:success it runs.
and ideas?
You plumbed everything back in yeah? TMIC, boost compensator etc.
Captain Standard
Connor Wrote:Connect the throttle cable?
lol yes it seems very unresponsive though
it also is not the easiest to start
i think every thing is plumbed in correctly with all new jubilee clips
You tuned up the pump properly? Wound the max fuel screw in etc.
Captain Standard
Toby Wrote:You tuned up the pump properly? Wound the max fuel screw in etc.
i havnt touched any of the tuning yet. it was like it wasnt coming on boost properly. i havnt got my boost guage on to see what psi im running.
So, it is running, the car is driving from A - B??
It's just a lumpy engine now?
That LDA screw looked a bit iffy to me, but im assuming someone lost the old screw..
What's your fuel screw looking like?
I havnt looked at any of the internals but I will tomorrow when I get back from work
So what could it be?
Ben Jay Wrote:So what could it be?
It could be just poorly set up? Sort out the max fuel and LDA screws and see what happens? Smile
Captain Standard
You need to set up the max fuel on the pump that will be why it feels flat, get your 13mm spanner out, slacken the lock nut and screw it in by hand until the revs start to rise and if its hard to start I would say that it possibly needs advancing a little bit Smile where is the pump sat on the mounting slots?
adjusting the max fuel requires no internal work, just loosen the nut off, screw with your fingers, get the rev's higher, give it a rev (check for smoke) i run mine with a light dusting off half throttle, that seems a nice level, tighten the nut back up, and adjust the idle back to normal...
What we are thinking is that it's getting way to much fuel which means its bogging down due to this. An I right?
Ben Jay Wrote:What we are thinking is that it's getting way to much fuel which means its bogging down due to this. An I right?
Sounds more like too little fuel?
Captain Standard
Little fuel mate - you'd have little chance of bogging down imo.
Did you prime the fuel through, as well as 'overflowing' injector return lines?
I'm no expert on these as you may know, but seems as if an air block - basically, little fuel getting through..
It wouldn't air lock I wouldn't think, too little fuel, and again, as per my last post, how advanced is the pump in the slots on the mounting points?? because if its running retarded it will be a bastard to start and really flat to drive!
If it was too much fuel to bog it would smoke like a mutha. You would know about it haha. But in the turbos range it would go well
So if its just stupidly slow then too little fuel
It was smoking like a train when we were running it that's why I think to much fuel
**facepalm** did you not think to mention this?? if you did and I forgot I'm sorry, this has been going on for a while lol
What colour is the smoke? is it black?? or grey?
how advanced is the pump? as this could be your starting problem and smoke cause!
White/light grey smoke?
Il bet its running to retarded like Mark said. When they are too retarded they literally just pour out white smoke at idle...
Dan! Wrote:White/light grey smoke?
Oh good, I'm not talking to myself, was beginning to think nobody could hear me lol
mark_airey Wrote:Oh good, I'm not talking to myself, was beginning to think nobody could hear me lol
They can't, they can only read :geek:
/grabscoat
/grabscoat
lmao being as pedantic as I can be at times I can't really argue with that Tongue
So too retarded could make it run flat?
Mark - what do you mean by running too "advanced" ??
You need to get a video of this... you provide so little information on your setup, get a video of your engine bay, how it drives, idles, revs, and show your fuel lines and throttle response, and smoke when you rev it. Its just a total guessing game saying it wont rev................. could be so many reasons, of which we could sit here guessing them all.
  Lucas to Bosch Conversion Phase 2 306 DTurbo FrostyHDI 2 1,692 01-12-2015, 02:43 PM
Last Post: Dave
  Bosch pump conversion problems Farmer-Glen 16 3,526 16-09-2014, 07:08 PM
Last Post: Farmer-Glen
  Bosch conversion nightmare sammyb303 11 2,543 04-09-2014, 08:04 PM
Last Post: Chris_90
