De-locking help
removed the rear lock from the car and all wired up it unlocks fine. the problem is that it doesn't return to the neutral position so it doesn't 'lock' again without physically moving the spoke back across to pull the solenoid back to its start position. is this an issue with the solenoid or is there a way of remedying this?
Use a spring to return it to its original position
  Central Locking and locking in general. LadySteve 13 8,913 31-08-2013, 01:02 PM
Last Post: devils_fuel
