For Sale: top strut brace
Forgotten the make.
Had it ready to fit for ages...but I cant get the clearance with the 2.1...and now with adjustable dampers.
£35 posted takes it Smile
[attachment=18935]
Again....thanks forum bugs for rotating my pic! Lol
Fits all models??
Er no.
Wouldnt think it would go round a tmic! Lol
Bump, no one?
Roughly how high is the bar above the line of the strut tops? Just to work out whether it'll clear on an HDi, particularly with possible future intercooler pipework in mind.
Duno for sure as I cant fit it due to height of the 2.1 engine.
I can try and fit this week with mani removed if you like?
Just lay it on a flat bit of ground so the ends that bolt down to the struts are on the ground and measure the distance between the bar and the ground - should give a close enough idea.
Looks like a very similar design to the omp one so should clear a hdi fine.
Will check later.
Anyone know of one with better clearance? I tried one for a xud tmic and it fouled the gti MC. Angry
can you not make your own so it suits the 2.1 perfect? Smile
May have to. If no one buys this, it will get chopped up to make one!
This may answer your question:
[attachment=19042]
(15-09-2014, 11:20 AM)Piggy Wrote: May have to. If no one buys this, it will get chopped up to make one!
take a look at mine you recon that would fit? id sell you that and just make another up.
Yeah probably would actually.
You running a GTi M/C?
id assume so as the estate runs 266mm brakes as stock so would need the bigger m/c ?
Duno, random MCs they are
Nah, only the later ph3's (~X onwards) got the GTi MC, the older ones with 266s had a 22mm one. No idea how big the phase 1 was to compare though.
He only has a ph1 front end tom
Oh and my ph3 W reg had a MC as standard, 1.6 petrol meridian!
But its on a ph2 estate isn't it? So wont be the GTi MC.
(15-09-2014, 05:05 PM)Toms306 Wrote: But its on a ph2 estate isn't it? So wont be the GTi MC.
Yeah I would assume it isnt.
Whats the clearance like with the MC you have Ash?
iirc it is a 22mm one on there actually. not sure on clearance think theres a few piks when i first made it in my project thread.
Anyone?
Otherwise it gets chopped and welded up to make me a custom one
  FOR SALE: Phase 1 DTurbo Sparco Strut Brace Eeyore 6 5,018 07-09-2016, 05:44 PM
Last Post: bashbarnard
  OMP Strut Brace RetroPug 5 4,056 13-12-2015, 11:36 AM
Last Post: RetroPug
  Strut brace (OMP?) silverzx 4 4,106 07-10-2015, 12:58 PM
Last Post: silverzx
