Threads: 591
54
Sounds like you need more boost...who done the map?
Threads: 386
87
07-09-2014, 09:39 PM
(This post was last modified: 07-09-2014, 09:41 PM by Toms306.)
That's the problem with manual boost control and no intercooler...a hard stage 1 will always be smokey. Looks alright to me though...same as mine with the straight through.
Threads: 117
119
How long ago did you clean the back of the car?
Shouldn't be very smoky on a stage 1, or ever really, the HDis don't need it. Rob's probably on the money, failing that there's most likely a problem with the map. Whatever you do, don't increase the boost on stage 1, it'll cook the intake charge and gain you the sum total of FA.
Threads: 85
8
Car Model/Spec: E90 330i
Yeah, the stage 1 you did for me doesn't smoke much at all. I enjoyed it for the best part of a couple of weeks until the clutch decided its had enough lol
Threads: 91
2
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Dragging this up, I thought I'd let you know the sootiness has cleared up loads since I changed to new Siemens MAF and refurbed TPS. The MPG started to drop from a regualr 52ish to 39. Looked for boost leaks but there was none. Took a punt on an ECP deal on the MAF (half price) and fitted with the refurbed TPS and car is much more keen to go. Much less soot now.
Just a buzzing LP pump to change now (also ordered new Siemens on the ECP deal).
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Mine smokes like a Bizotch... It's leaking more boost than a land rover leaks oil, but I haven't got around to changing it yet as I have an fmic to fit..
Only smokes when I realt Mat it..
/Toseland
