04-09-2014, 06:49 PM
Anyone on here or knows of reliable person that can rebuild and replace the seals on these Bosch pumps?
Bosch pump rebuild
04-09-2014, 06:51 PM
Have a look at this guide - http://www.brick-yard.co.uk/forum/ve-inj...17456.html - and consider doing it yourself. Could learn a lot about how they work in the process!
![]() EDIT: My bad, linked the wrong URL. This one should be better.
04-09-2014, 06:56 PM
theres afew of us on hear that can do it mate inc myself stick a wanted thread up im sure you will get some replies
04-09-2014, 07:54 PM
I've just rebuild mine due to a leaking main shaft seal. Bought the kit from Darwen diesels which was aboot 16quid I think. The guide above is very good, some bits here too - www.eastment.net/index.htm
Plenty of rags and cleaning gubbins, plus a DECENT torx bit set/ socket set and measuring device ie digital caliper.
04-09-2014, 08:16 PM
I want to buy another one to rebuild soon and 11mm. Then put my one on other halves car so I should be able to make use of a few guides on here
04-09-2014, 10:22 PM
(04-09-2014, 08:16 PM)bashbarnard Wrote: I want to buy another one to rebuild soon and 11mm. Then put my one on other halves car so I should be able to make use of a few guides on here Probs the best way, rushing it could = failure. I had a spare off my old 205 for parts just incase. TBH most of the seals are a certain shape/size/material so it's easy enough to identify the new'un against the old'un. I am still tweaking the pump as I put it on an XUD11 engine, it ain't pissing WVO out so it's all good
| Slack in bosch pump? | dt_ | 14 | 11,486 |
21-10-2020, 03:41 AM Last Post: dt_ |
| Bosch pump help for newbie | PugRy | 2 | 4,388 |
05-01-2020, 09:09 PM Last Post: jamie182 |
| Bosch pump fuel screw broken | Forby | 0 | 3,065 |
12-03-2019, 06:47 PM Last Post: Forby |
