Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
If it stops when you.put the clutch down probably release bearing on clutch. So new clutch kit time
Threads: 59
3
Car Model/Spec: 306 D-turbo
Given 0 thank(s) in 0 post(s)
Yeah more than likely release bearing to get to it it's gearbox off so while your at it get the clutch changed.
Threads: 23
0
Car Model/Spec: 306 HDI LX/ Mondeo Ex Police
I was thinking the pressure plate, dam that is guna be expensive .
The Black PH3 Angel
Threads: 371
29
What sabb is it? Year etc.
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Have fun, subframe job lol there will be a DMF on that aswell (guessing its a derv) so check that for in and out play while clutch is off (you will get ~2mm side to side), if thats buggered its around 300 quid for a new one
Threads: 23
0
Cheers for the heads up lol still will be a pain to fix, it is a saab 95 turbo 2001 2.0L se
The Black PH3 Angel
