Remove helper srping or new top mounts?
Yes, is that question, I have 1 finger of wheel gap and the coils on minimum level.
I wanna get more down, what you recommend?
[Image: sign.png]
↑ Project ↑
Shorter, stiffer main spring.
What you mean? Other spring but more "compressed"?
Because Sent by Tapatalk is too mainstream!
[Image: sign.png]
↑ Project ↑
Shorter free (uncompressed) length, higher spring rate.
At least that's what I assume!
[Image: sigcopy-1.jpg]
Seid' Wrote:What you mean? Other spring but more "compressed"?
As kezzi says mate, you need a shorter, stiffer spring to go lower, removing the helpers would run the risk of the spring unseating when the shock extends!
Team Orange Engine Bay
Yeah, but that lower spring is very expensive, more and less the cost of the coils :/
[Image: sign.png]
↑ Project ↑
Depends, you can raise the lower spring collar to the top of where the helper spring sits, then remove the helper spring, will have the same effect.
cwspellowe Wrote:Depends, you can raise the lower spring collar to the top of where the helper spring sits, then remove the helper spring, will have the same effect.
As far as I understand it won't though, the helper spring compresses a good 40mm and doing that will result in the car sitting higher that standard if I'm not mistaken!
Yep, 'cause the spring rate is now a lot higher.
Rippthrough Wrote:Yep, 'cause the spring rate is now a lot higher.
See, I do listen to you Tongue
's about time some fecker did, I feel like a stuck record in here.
Cut the springs Big Grin
Stage 2 XUD Sedan
  Who removes helper springs? pugtk 4 2,777 11-01-2015, 08:53 AM
Last Post: adam b
