Bosch woodruff key.
Bought a pump with a misplaced woodruff key. Wondering if Peugeot will stock it or (by any chance) is anyone has a part number for one. Cheers
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
I rang pug about them. No longer made. You have to find a dealer with one in stock
you could try some bosch specialists, scrap yards or members on here
or get one made?
take to the local machine shop
/Toseland
1931 22 , not marked NFP, dealer probably talking utter bollocks and can't be arsed getting you one.
try darren lobb, he has dozens of broken bosch pumps, bound to have some woodruff keys Big Grin
servicebox says same as a lucas pump btw.
The dealer inuse is usually good with most things. Although thinking about it I dont.think I gave them part number like I normllly do
Any shafting / bosch dealer can get you one, its just a woodruff key..failking that, just make one using a bit of steel, the woodruff key is purely to align the pulley on the shaft, it dosnt take load, the taper locks take the load...and wont matter if your slightly out anyway given the pump is on adjustable slots anyway. Alot of factory cars of same generation were fitted with no key at all, just line it up best you can and get it right on the slots.
Sourced one from Peugeot. Just supplied a part number and they found it straight away. £1.20.
Cheers for all the help everyone! Much appreciated!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
  Woodruff key knackered jakkkey 2 2,469 26-01-2016, 07:21 PM
Last Post: bashbarnard
  Woodruff key aggyj17 17 7,749 14-04-2014, 09:00 PM
Last Post: DarkInferno
  woodruff key Piggy 9 6,417 27-03-2013, 09:12 PM
Last Post: wonkey18
