Threads: 41
3
Car Model/Spec: 306xrdt ph1
Has anyone got a left over XUD11 gearbox and driveshafts ?
I need something with cable shifters and hydro clutch. It seems easier to start with a box that has it and I believe it's got a better ratio set for those that like to sit at high motorway speeds.
Threads: 591
54
I would be VERY surprised if you could fit a xud11 in the 306 bay. Its only a 5speed but its freaking huge.
Threads: 42
28
ML box fits fine, apart from needing to reliee the subframe for the diff and shortening the shafts, and using the intermediate bearing carrier.
Threads: 41
3
Not going into a 306 tho, going in a Honda with cable shifters and a hydro clutch.
So change the Honda over to linkage and cable clutch is a royal PITA.
Will be cutting anyway (inc custom shafts), so hey ho.
No ML 6 speed ??
Anyone got one ?
