Help lost all brakes
Need some ideas my peddle goes straight to the floor and nothing happens need my car tomorrow :/
Thanks
Fluid leak
Dead master cylinder
Air in system
Few possibilities
Team Doesn't own a 306
Drums or discs on the back?
I'd say either a flexi hose has split or a slave cylinder inside the drums is leaking.
Drums yeah my slave cylinders are leaking but I have plenty of fluid wouldn't have thought that would take my hole peddle away
the cylinders need replacing then, for the brakes to work it needs to be a sealed system, it won't matter how much fluid there is, every time you step on the pedal, it'll just pump the fluid through the leak - no brakes
Project: Formula Peugeot
Cylinders leaking....
Yeah that be it lmao
New cylinders and shoes will sort it mate Smile
Just have to use the handbrake for a min then
The handbrake wont work now the shoes are covered in brake fluid... :facepalm:
Well my car parked on a hill now seems to be in the same place lol
Hmm, I guess you left it in gear as well....if not, lucky haha! lol
Must be lucky ahah
So, you know you've got leaking wheel cylinders, and then drive it around and wonder why you've lost all the brakes?
Seriously?
locking before this turns into another Should know better thread
  Brakes lost there bite DeeTurbo 45 25,453 14-12-2014, 07:39 PM
Last Post: DeeTurbo
