Fuel filter change
Fuel filter change
Bare with me...
I've NEVER needed to change my fuel filter but now im running S/VO it must be done.
Am i right in thinking:
- buy new filter http://www.ebay.co.uk/itm/FUEL-FILTER-P ... 3372078b1b
- take old one out
- new one in & fill filter and housing with diesel
- put back together, done?
Apologies for the noob thread.
Yes. And give it a good prime. Mine fired up no issues doing it like that.
Stage 2 XUD Sedan
strictly_derv Wrote:Yes. And give it a good prime. Mine fired up no issues doing it like that.
yeh, forgot that.
swish ta mate - i'll leave this thread alive anyway, just for forum users in the future.
You dont need to fill it up because the diesel stays in there when you take the filter out... so old out new in tighten down then prime couples times all sorted Big Grin
tomw1123 Wrote:You dont need to fill it up because the diesel stays in there when you take the filter out... so old out new in tighten down then prime couples times all sorted Big Grin
technically it should be full of veg oil anywho whistle
I should of said fuel instead of diesel Wink
tomw1123 Wrote:I should of said fuel instead of diesel Wink
lol :clap:
I'll top up the filter and prime to just be safe. nothing worse than getting an air block..
Forgot to mention after I put the new filter in, I primed it with the cap off so it was brimming then put the cap on to reduce the amount of air inside.
Stage 2 XUD Sedan
strictly_derv Wrote:Forgot to mention after I put the new filter in, I primed it with the cap off so it was brimming then put the cap on to reduce the amount of air inside.
Ah yeh! good point! Big Grin
Yep, this is a much better way of doing it.
My first thought initially was to suggest going to ECP as their filters are £3.. Then I realised they probably don't have a sales outlet on the IoW.. :geek:
Captain Standard
yeah just make sure you put the filter in the right way Ginge, it's very much like an LDA pin, if you rotate it 90 degrees it flows 20% more fuel higher up the revs . . .approx 3.7k to 4.5 . . . . .Wink
Mattcheese31 Wrote:yeah just make sure you put the filter in the right way Ginge, it's very much like an LDA pin, if you rotate it 90 degrees it flows 20% more fuel higher up the revs . . .approx 3.7k to 4.5 . . . . .Wink
you are shitting me... :naughty:
Cheeseneister is right
There is a small arrow on the filter and housingto line up :-)
4WayDiablo Wrote:Cheeseneister is right
thought everyone knew that . . . . . . . .well you gotta start somewhere i suppose . . . . . lmao
Swap her out and crank her up, sheel be reet, bit of priming helps.
Exclamation Swarf In Fuel Filter Housing jordanhdi 11 5,915 26-09-2016, 11:55 AM
Last Post: pug306driver
  oil and filter change and a big can of worms alex76 7 3,591 19-05-2016, 09:32 PM
Last Post: alex76
  Removing the fuel filter housing, but what is this behind it? Iaitoo 2 3,039 27-04-2016, 05:33 PM
Last Post: Iaitoo
