Threads: 3
Car Model/Spec: 99 D-turbo
Right, last while the dash has been acting up, rev's sit at 2k, everything else drops off. Happened today, turned off and went to start again and now no lights on dash, no life in her, not turning over or clicking. anyone ever had this before? battery has charge and alternator is good
Threads: 151
14
Car Model/Spec: 306 D-turbo
Sounds like a earth issue
Team Doesn't own a 306
Threads: 252
7
Def earth our estate does this just knock bat neg its ok again
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 3
is there a guide for the wiring diagram? couldn't find one in the guides. and who ever put the alarm in did an absolute hack job on it.
Earth points by gearbox and under dash by bonnet pull are common. Check battery terminals too. Big ass plugs by gearbox chassis leg also gunk up.
Threads: 62
10
Main battery earth is broken.
HDi Owner for 200k/9 years
Threads: 3
Ill have to go down and check once this bloody rain passes, great weather to be working on a car NAT
